Super Jet Bilge issues?
Utah
I went to the lake yesterday and my bilge wouldn't shut off. I have the switch that mounts on the underside of the start stop. When I hit the off button for the bilge it cuts the bilge speed in half but won't shut off. What do you think?
OCD Solutions
Rentz, GA
You could just have corrosion shorting out between connectors but those CPI switches are also prone to water penetration thru the wire insulation. Eventually they soak thru enough that they short out the switch. I had one dog me for months draining my battery down between every ride until it finally got to the point that I could hear the pump running.
The switch and immediate length of wire seemed okay but the extra length that they spliced on to extend the switch was where the problem was. If this is the case, you should be able to splice a new chunk on.
Utah
I'll check that out. I just thought it was weird that on was full speed and off was half speed. Thx for your help.
An year later after lots of salt water the switch and wire harness I got from you are still running like new, I strongly recommend them to anyone.
D.
My bilge was doing the EXACT SAME THING! Went riding, came home heard the bilge. Thought it was weird, went to click it the other direction and it just doubled in speed.
Mines less than a year old and have been using it in the salt water 3-4 times a week for the last month. I've got the handlebar switch one from Blowsion (hot products) probably like yourself.
I've been looking into getting OCD's Switch. Very nice and seems like a 1 time purchase. poop, I wish I got it from the beginning when I knew what I was doing.
Utah
I agree. I was gonna take a closer look this weekend to see if it is something obvious, like some of the things mentioned above. But if not, what a waste of money!
IS0LD0UT
I hate winter
MN
Same thing happened to me. 2 switches later went with a cheap menards waterproof switch for $8.
swapmeet
Brotastic
Arlington TX
The OCD switch is slick.
On my wifes SN, I have two wires with a male and female connector sticking out. Put connectors together, go ride LOL... Ghetto Fabulous but it works and its better than twisting two wires together or connecting it under the hood.
OCD Solutions
Rentz, GA
If you ride freshwater then the standard military toggle will work just fine but if you ride any amount of salt water then I strongly recommend the "Surf Armor" switch for years of trouble free service.
Utah
Thanks for the response! Is the military toggle just as good as far as the grade goes other then the additional coating for salt corrosion? I'd like to get a switch that I don't have to screw with every season. ThX!
i've had a bar mount switch go out on me, didn't realize it until the battery was dead the next day (shoot me)
things happen. OCD switch is nice but i prefer the switch at the bars, for ease of use. I don't run the bilge the whole time i ride, only flick it on when needed and shut it off when it's done.
Utah
I wouldn't disagree with you, the design of the cpi switch/mount is very nice but the reliability is the issue. Since I've had this problem I've talked with others who have had similar issues. I haven't found anyone yet that has any bad experiences with the OCD dude. Plus for the price, it seems to be a no brainer.
OCD/Boyer is a good guy. I run a couple of his bilge wiring harnesses on my skis. (boyer still haven't pulled that single kit off to swap with you)
he does great work, and if i ever go to a dash switch, i'll probably use his, but at this point i'm sticking with the bar mount.
can't go wrong with his products.
Utah
I don't like the idea of a dash mount. Are there any other convenient places to mount the OCD switch?
Utah
could either zip tie it to the bars (ugly) or drill a hole on the underside of the pole and have it on the bottom there. most of that would be personal preference than anything.
I'll have to take a look at it tonight. I guess the advantage of putting it on the dash is not having to run the wire for very long as opposed to the handlepole....
