i modified my bracket to use zipties instead of the thin clips and i also glued it in with some silicone. its epoxied 25% of the slots are blocked but its not going nowhere. i laid one layer of glass under the coupler area and while it was still green got the bracket stuck.. solid!Does anybody have a problem keeping the damn bilge pumps from ejecting from the blue bases?
Not breaking off the tabs just simply coming off from surf abuse.
My first bilge blew up for sucking something up too big, then my second one just fell out in Oregon and my driveline got it pretty well while taking one of the bracket loops on the side off.
I feel like i buy bilge pumps more than i buy oil or spark plugs. so right now im not running them and I am very vulnerable in the surf with just my scupper... oh wait it did sink:icon16:
User Attwood pumps ,they don't bind up
if i put another 500 behind the gas tank can I run the plumbing back to the same outlet hole?
Attwood pumps cavitate too.
http://www.pwctoday.com/showthread.php?t=188734&highlight=bilge
:mischievous:
This will not cavitate. Rulemate 1100 gph. (750 if you want to use stock bilge fitting) It has a Floating ping-pong-ball switch. Throw your crappy handlebars switches away for good! The only time it has failed me is when my battery was dead. Plus it pumps like a mofo! :usa2:
ps...this does not pump every couple seconds. It is always on when needed and always off when not.
...i drilled another line through the hull for my dual cooling line... even if both my bilges die, like they did sunday, at least i still have the stocker to suck some of the water out.
Which model is it? I've never had a V-series airbind like the Rules do.
Yes I went to Wal Mart the other day to check out the Attwoods and the one I saw was hour glass shaped and wouldn't fit in my bracket. Do they have other models or do you mount them a different way?
They'll fit with the Blowsion bracket - you just have to redrill one of the three holes..or just use two. The new attwoods still fit under the cover beside the shaft like the old ones. Theres a post on here somewhere comparing the two. I haven't used mine yet having just got my bilge outlets I still have to drill the holes in the hull and connect the hoses. I'm going to be using the stock one and two 500 attwood tsunamis...
I switched from dual Rules to the Attwoods with the outer cover cut off.
