OCD Solutions
- Rentz, GA
12 volts to ground is nothing, just don't get between those two wires and become the fuse for your bilge pump. Load changes everything, LOL.
I used to run the handlebar switches but after a couple failed switches back to back at $100 each, I switched to the rotary dash mounts. I still like the idea of the handlebar mounts but make sure you buy the military spec ones or they are a waste of time.
If you always ride with your bilge on, I'd consider the relay kit that pulls in and activates your bilge whenever you hit your start button and stays on until you hit the stop button. I'm going to do my next one that way with a 3 position rotary switch on the dash for on/off/auto with auto working off the start/stop switch.
