Bobert540
- Rockford,MI
I had dual 46 blackjacks on a ported 61x Topend. 83mm stock 62t cases Ada head b pipe stock pump with 12/17 big hub swirl nozzle bored to 85 and it ran great in my SJ
There are likely some internal differences but the main difference is the fuel delivery into the throat of the carb. The Blackjacks use many holes around the inside of the bore, no protruding atomizer, the buckshot uses a single spigot atomizer and the novis use a bombsite style atomizer.Can someone explain the differences between blackjacks, buckshots, and novis? Are they just different companies, or do they do different modifications?
Oh nice thanks for the response! It seems a lot of the pros use novis is there an advantage to the bombsight style? Better fuel delivery for larger engines etc?
As well as Red Tops, GRE/Jack Green, Buckshot, Pro-Tec, Riva Billet and I am sure some others.Black jack is the only one with a non bomb sight?
Everyone likes one a little more than the other an stay loyal to it, all arguments usually include three names, novi, fullspec and blackjack. Buy a wetjet intake mani and any of the aboved named carbs in a 46mm and you will have a hard to beat setup for 61x cases
i wish i had all the money that gets wasted on insignificant mods....................
