- Jersey Shore
Mandrelbendingsolutions.com is where I buy everything.
They are called T-bolt clamps. You can check McmasterCarr or your local FastnalWhat kind of clamps are those in the picture above? Would like to get some for my exhaust system. Standard hose clamps worry me! Thanks
I don't know about their set up but if you are just using a 760 box you can do it without cutting anything. I just finished mine.Another question for you guys, is is possible to install the rear exhaust set up without an access panel on rear deck? Cant be easy but how about just using the battery box hole?
When will this be added to the store? I've got one of your rear exhausts on the way and this would be perfect to use with my 1200 swap.
