Blaster Blaster 1100 Kawi Exhaust setup Rad Dudes
Stock 1100 waveraider box has a different intake tube size than the outlet of the kawi 1100 pipe. You could either buy a reducer to make the change in diameter work, or cut off the inlet tube of the waterbox and weld on the proper size. IMO, unless you have access to a welder, just buy the rad dudes set up and move onto a different part of the build.
SM
Like Scotty Said, the box is cut drilled intel is changed the 2.5 and exit gets a special cut for increased flow. Then everything is rewelded and powder coated black.
We also do sell a 90 alum with a 45 silicone to get from the water box to the exit. Its a part we need to add to the site.
dliibal88 if you need anything let me know just PM me and ill give you my number to call so nothing gets miss read in an email.
Thanks
Mark
We will also have out demo 1100 at the Rapids Race this weakend in NY.
Twinturbostang, could you please update your website with the piping and hoses needed for the conversion on the 1100 Blaster, I have your complete kit just need the last few bits...
Michigan
What kind of clamps are those in the picture above? Would like to get some for my exhaust system. Standard hose clamps worry me! Thanks
Another question for you guys, is is possible to install the rear exhaust set up without an access panel on rear deck? Cant be easy but how about just using the battery box hole?
NY
I don't know about their set up but if you are just using a 760 box you can do it without cutting anything. I just finished mine.
It's a modded 760 box. A lot of water testing went into this box setup. You can't just stick a stock box on an 1100.
But yes it just drops in from the battery box area.
