What is involved in swapping a 96 yamaha blaster 2 760 motor into a 97 round nose hull?
I plan on using the SJ gas tank/ fuel pickup, 650 bedplates, SJ motor mounts, SJ exhaust, and SJ midshaft.
Then swapping the e-box, dual 44 carbs, and coupler from the blaster 2 760 motor. Would that work? Can I use the motor mounts and bedplates from the blaster 2? The bulkhead bearing assembly looks the same as well, is it?
Thanks in advance for helping me with my Frankenstein winter build.
