IN THE HOOD.
I want to go over the Surf Mods I recommend for the hood area. When it comes to working under the hood, the factory catch , apart from being awkward, it does not allow the hood to open enough. This is easily solved by fitting a pair of gas struts. The 701Dual Hood kit comes with everything you need to get rid of a old school latch and bring your Blaster into the modern times. Now not only does making opening your cowl a breeze, from either side of the ski, it gives you way more operating room to work on your motor. In the closed position, with the gas struts under tension, this goes a long way to making your hood more stabile. The Dual strut kit now comes with a couple of cover plates to go over where you remove the existing old school bracket.
For surf riding, you will be applying a lot more forces on the hood . You are transferring a lot of pressure from your wider bars, down through a taller steering. You need to lock this hood down to limit movement. Its never nice when you rock on the bars and see the hood rocking with you. The main source of this sloppy hood is the factory hinge. As the skis have a lot of years under them now, its the small things that if replaced make a huge difference. 701 sells a H-D stainless steel ball bearing hinge that comes with all new mounting hardware.
The 3rd essential item I recommend is to run a good seal. The seal, not only for keeping out the water, but it makes for a strong hood. The OEM seal in my mind has always had issues. It doesn't have a memory, so when the hood was closed and a part of the seal gets trapped, it will stay that way from then on. The 701 Seal is a basic channel that replaces the OEM one but is made wider to accommodate reinforced hoods. The kit comes complete with the glue and a applicator .
Members on this forum that have taken these steps in preparing there Blaster for freeride, will im sure agree with what im talking about. All these Surf Mods are available through the 701Industries online shop. You are also welcome to email me direct at
dave@701industries.com if you want to find out about anything. Cheers
