the WaTeRhAwK
fryin' up a/m electrics..
- okc
laserpope it.
regards.
regards.
girdle it.
518 it.
This motor is only 11 months old. Only ridden 5 months! (25 times total???) Do you guys recommend full rebuild or just replace the 1 piston, both sets of rings and 1 upper bearing? No cyllinder damage and no ring damage, (nothing fell below the rings)...
DJ, r u torquing the end bolts to proper torque with a wrench. I know its a pita, but the watcon tool works well for doing that.
I had the cyl head that you had to machine the cyl. Sucked getting it done but worked great, no bolts at the bottom. SXRs are famous for cracking the cyl on the corners so i figured id do everything I could to save it.
Well, I was going to order pistons today, 2 sets for 2 cylinders. Some crap happened and now I wont be ordering snot. Oh Well. Hit the water again in August maybe.
we can start a "get harrison on the water" fund.
I tried...lol![]()
