KTM434
Jamie FN Hickey
- Palm Coast FL
I think your enhancer is fine. I've never seen an enhancer cause overadvanced timing. I've had enhancers fail causing the ignition to cut out briefly and fall on it's face then continue to run normally until it cut out again. Just make sure your stator plate isn't advanced too much (rotated counterclockwise) especially when running an enhancer since they advance ignition timing by 6 degrees at lower RPMs for better throttle response. I'd rebuild the engine and carbs then just take some plug readings on your first few rides and make sure your carbs are jetted properly
