- St.catharines, Ontario
on a 701 ?? I wanna see that, post pics please.
http://www.x-h2o.com/threads/102838-first-backflip-attempt
I can however comment on cutting the PV springs, cutting a coil off the spring increases the spring rate making the remaining spring stiffer, the PV's may initially open quicker due to the shorter spring but through the rest of the travel they are now fighting against a stiffer spring, it is not the correct way to achieve the desired results.
You might want to do some research on that, I have already
Imagine a 10 coil spring sitting upright on a table. You place 200 lbs on the spring. The weight moves the top of the spring down 1 inch. So your spring rate is 200 lbs per inch. Each one of the ten coils has shrunk 1/10 of an inch.
Now cut the spring in half. You have 5 coils now. When you place the 200 lbs on it, each coil still shrinks 1/10 of an inch. (same diameter coil, same amount of deflection.) Because there's only 5 coils, the spring will only move down 5/10 of an inch.
This gives you a new spring rate of 400 lbs per inch. Twice as short = twice as stiff.
Please share your obvious expertise with the rest of us.
chucky told me 850cc+ for PFP
What about Roo's freak right now.701 wetjet w a pfp. Riiips
Sent from Fro Diesel using Tapatalk.
There is no pics in that thread only one vid. the link in the last post is wet jet pipe.
the pfp will make a huge difference on anymotor. roo on here was talking about how great his 701 runs with one... i've preached about dry pipes since i started riding skis 2 years ago.
