Other Bpipe vs. PFP
Half flip95
Formerly pondracer95
this is a very rushed together setup, hope some of you get some laughs out of it :party: i literally pulled out my 1000cc longblock motor, and dropped this 701cc motor in place of it along with stock electronics. (whole reason i did this was because i sent my xs1000 down for a rebuild)
the setup pictured below is as follows:
-61x 701 WetJet motor (w/single 46mm carb), 145mm setback mag (13/19 prop), powerfactor pipe, stock ignition
the pump is setup and pitched for my 1000cc motor (145mm setback, 13/19 prop). as is, it is a little ripper but could use some more low end which i am confident once re-pitched, would make a world of difference. i do have a stock 144mm pump with i believe a a lower pitched prop i should try, but honestly just have been bit lazy about swappin' it.
two other things i'd like to try is adding a waterbox for back pressure, and switching the electronics over to total loss and play with the timing.
bump for the most jenky enginebay ive ever seen
Flash-FX
No Square..No Round..FX-1
Since the dust has settled years ago, I found that the "B" pipe is good for a stock motor mod. The minute you start going bigger, use the PFP. The big problem with the PFP is that it isn't designed to fit with all the stock trimmings, 4.8 fuel thank, battery tray, ect. 97 SJ sums it up with "it's all about the whole package".
