- Los Gatos, CA
Which nose piece screw? Haven't noticed it yet on my ski.
It was most likely never screwed in correctly. Now stripped. Just squirt some 5200 in there and add a new screw. Done.
Sent from my SAMSUNG-SM-G930A using Tapatalk
SXR's are terrible without a pipe! honestly seams like they're using atleast 30% more fuel than my superjet.does adding a b pipe greatly reduce fuel efficiency, or is it not noticeable? My friends sxr 800 is terrible.
How is it compared to a stock SJ?with a b pipe on my sj the fuel economy is a lest 25% better than a sxr 800 and the same as a axr 1500
//uploads.tapatalk-cdn.com/20170820/d14c8cbcf5554ed95f1a1d569e4c3de6.jpg[/![]()
Is that a crazy joe hull next to superjet
You ride it surf
These are top of the line most expensive easiest rolling in soft sand Best totes I have ever used IMOor this? is it essentially the same thing anyways? this is made by factory zero.
About once or twice a week for the past 5 weeks. Going tomorrow to ride in Ventura
if you can find one. ended up with the jetlift cart.These are top of the line most expensive easiest rolling in soft sand Best totes I have ever used IMO
