- Tuscaloosa, AL
now seeing that pic of the shoe on my computer, that is messed up looking. angle looks all out of wack.
Think I had the JD Pump Shoe.
From this I new I would need to move the hull side hood hooks as far forward as I could. I started by moving these forward and as “square” as I could. I then left the hood prongs on loose and latched the hood down. With it latched, I pressed down on the front of the hood and tightened the top hood prong bolt since I could get a wrench on it. I tightened everything down and tried a paper test to see how the hood sealed. The hood latched fairly tight. The two papers on top were the only ones that pulled out.
I decided to break down the paper to smaller strips to get a better reading on where I didn't have a good seal. After more reading of the hood and tweaking on the prongs and hooks I ended up with a decent seal. The papers in my hand are the only ones I could pull out. This was the best I could get it and called it good for now. She will run this way until I have a problem or learn a way to do it better.
Oem pump shoe for life ✌
If I ever build up another hull OEM.
So my current thoughts on pump shoe. Please share your thoughts of PM me if you have any advice
or
- Thrust said I have the right one just cut and grind current one to fit, that's what they do.
I guess I'll think on it today and either hack tonight or order something else....
- Buy a OEM style WB2 plastic one from JM $110. Is strength and fit OK? Holes for intake grate are already drilled, hope they line up.
- Buy a Jet Dynamics OEM style 155 from JM $117) Hows the fit? Holes for intake grate are already drilled, hope they line up.
