Freestyle Bun hull build (maxx hull)
denmark
Well Ear plugs a out, worked like a champ. Mounted the pole bracket from ATP and it was not that great.image.jpg
That did NOT lind up, think the Bun bracket Will fit nice. Maybe maxx should safe him self the time, and dont drill any holds.
Drillede it out and all is got, probs too ATP bracket is looking good. Next was motor mounts i am a firm beliver in GP mounts, hade too drill the holds 1 mm bigger too Line up with hull inserts. Prombly have too goe bigger when aligning the engine.
Cart tank fitted like a glove, missing a strap though.
England
Yep, just checked my hull that has the ATP bracket on and your is backwards.
Hull looks great tho, was tempted to buy one myself!
denmark
Well how the fudge did i miss that, thats a rookey mistake. I see it now the breathers wont fit, Will take apart tommorrow. And reverse the top off the bracket.
Well how the I used a bad word did i miss that, thats a rookey mistake. I see it now the breathers wont fit, Will take apart tommorrow. And reverse the top off the bracket.
you probably thought the ATP engraving should be able to be read while standing in the tray. its upside down as far as i'm concerned and engraved wrong
yamanube
This Is The Way
Staff member
Mandalor
You have to reverse the entire bracket, or it will not work right with the stop and the breathers still won't be in the right place in relation to the bolt (especially if using a spring). The text on the bracket is not for you to read while riding (not that you could, the pole would be in the way) but for others to read as they walk past your boat and say "hey that's a nice piece of kit, I should get one from ATP".
