I need some advice on modding my Blaster just a little more for running in the Sport Spec class. I'm wanting to get a little more speed & handling out of it without breaking the bank. It currently runs around 46mph and I'd like to get it to 50-52. I'm finishing up a turbo couch build which will be the main ski I'm riding/racing/sinking $ into. I still rec ride both the RXP-X & Waveblaster too.
Engine mods I was thinking to lighten stock flywheel, rev limit mod on stock cdi, and dual carbs. Which dual carbs would offer the best bang for the buck though? Also, would I need a different CDI when going to dual carbs? Wanted to add that I'm not opposed to staying with a single carb if you guys thing I could still get good acceleration and speed with a single setup.
Handling, I was planning on some small sponsons on the rear, rear extensions, jet dynamics intake grate and shave the seat down some.
This is what is done to the blaster so far. I am running the single stock carb setup.
What would you guys recommend? Again, I am trying to get the best bang for buck mods but I do plan on spending some $.... Just trying to get across that I'm not trying to go all out and squeeze everyyyy bit of power I can out of it. Trying to make this more of my fun budget ski that could still be competitive in the spec class since I have my Turbo RXP-X as my fast one.
- 61X Engine, Premix
- R&D Head 170/170 Compression
- Factory B Pipe Header
- Mod Pipe Chamber
- Riva Waterbox
- Riva Intake Filter
- Riva Groovy Ride Plate
- Solas Intake Grate
