Ok, so the motor has northwest sleeves, that had been installed by Jeff jensen. It runs yamaha style dome (crown) pistons. Cases have porting work done, stock crank, custom cut domes from ada. Motor will go to 86mm. Its running 60 thousandths squish for pump gas. Compression is around 185ish if I remember right.
