SOLD California freestyle phantom
Ok, so the motor has northwest sleeves, that had been installed by Jeff jensen. It runs yamaha style dome (crown) pistons. Cases have porting work done, stock crank, custom cut domes from ada. Motor will go to 86mm. Its running 60 thousandths squish for pump gas. Compression is around 185ish if I remember right.
Jensen ported it too to muffler Marc's specs and muff put it together and tuned it. It absolutely rips for what it is
California freestyle phantom for sale. Has less than 20hrs of run time. Comp pole wdk steering, riser bars, big bore 771 ,bpipe, ada head with custom cut domes, all the electronics where redone and like new, limited slip tank, black jack 44mm carbs, new bearings in pump, has trim, to be honest cant remember everything that was done to it. Empty hull weighed in at 85 pounds . Extremely clean build, flips pretty easily, @zzylstra has rode it, and can maybe chime in with a ride review. Hasn't been ridden in almost 2 years
11k or best offer,
Is it infused or vacuum bag hull? I might be interested in taking a look. I’m in alameda
11k or best offer,
still got this? willing to ship to alberta canada?
New picture as of today, bump
11k or best offer,
We’re are you looking and would you take 7k ?
