nikad58
1974 YZ 701
- 200 miles west of Havasu !
I wana jump in did someone say Lisa ?? lol
i know someone who wants a lightweight hull:biggrin:
I am done riding..
#59 08-13-2007, 01:31 PM
PancakePete
I think that these threads are hilarious...
you see LPW getting knocked on here when people wait 5 months for motors... NOPE.
do you see the same when people wait 6 for team scream...
Or how bout when those motors blow up ..
NOPE not published...
Ya... all of the builders have good and bads... I just think its funny so many people beat companies up...
Reason 1,023,309,403,040,249,820,948.0 I'm sick of it all.
that was taken off my neg feedback forum of the new 24-7
Now who threw who under the bus.you had no business sticking your nose in their.but you had to cause your hangin out with you a$$hole buddy mark.hes nothing more than a squid thats gonna stroke you and stroke you like he is now. then screw you.i know ive been thrue it.
and yea i had someone post the pics for me cause i wasnt smartenough to post the pics look in my build thread i had to have someone post pics in that.
Again? Really Pete, I have nothing to say here one way or another about anyone's motors, but you really need to be careful not to lose credibility if you're trying to make a point. Perhaps you have something important to say that people need to learn - I don't know. What I do know is that your childish antics diminish anything that you have to say, which is a shame since you have a lot of insight and experience to offer. How many more times are we going to have to witness your histrionics, and watch you flounce off vowing never to ride again? It's just so tiresome....
This is my experience with Jr Magoos/LPW...
Before I get into this I want to say that NOT ONE WORD OF THIS POST would have made it to your eyes if MILF had not stated that Pete had nothing to back up his claim. That said, here goes.
Met Paul at Lone Star Freeride in March 2005 when one of my best friends received his engine from Jr Magoos. After talking with my friend and Paul I gave him $2000.00 for big bore DASA cylinder and pistons. At this time I also gave him a set of "t" cases to epoxy and port. A couple of weeks later I called Protec and bought 2 billet 6mm stroker cranks. I sent one to Paul and asked if he would clearance the cases and assemble the motor. I also sent him an ADA shell Factory Pipe manifold and "B" head pipe asking if he would get the correct domes for the new engine and clearance the pipe and manifold for powervalves. His reply to all was "sure." I asked him when he thought it would be finished to which he replied a month or two.
My plan after purchasing the two cranks was to build 2 identicle engines. At first he stated that he was having difficulty getting cylinders from Dan due to the sheer demand and short supply. OK. After he finally got the cylinder it took a while to get it ported and assembled. I spoke with Paul and asked if he wanted the other crank I had purchased in exchange for credit on my final bill. He said yes and I sent it with a friend to Lanier to hand over to him. I paid $678 something shipped for the crank. We agreed on this number to be credited toward my total. More time passes, we are now in late June. Call Paul and check how things are coming. He stated that the powervalve passages were not machined to the correct size and he would have to redo that himself. Another 2 weeks go by and check back with him. He stated he had the engine assembled and was running it on the dyno and it was making good horsepower over 150, but then began to abruptly fall off. He disassembled the engine to find that the cylinders were leaking water into the ports from between the casting and the sleeves. Stated that he had to take the sleeves out and "re-glue" them into the casting. This is where I began to have concerns about the build (never heard of sleeves being glued in, just cooled and casting heated then set into place or pressed and left to cool slowly.) Paul stated that he had a few things left to get it the way he wanted it but that it would ship out Monday. Monday a week later came and no engine. After talking to Paul same thing, "It will ship on Monday". This happened exactly the same for a few times. Finally I just quit calling to check being fed up with empty promises and lies.
Middle of September rolls around. Get a call from Paul stating that the engine had shipped. A few days later I finally get my engine. I take it out of the plastic bag it was wrapped in to find a blob of grease covered with metal shavings in one of the intake tracts. Next I do a mock mounting of the head pipe (the exhaust manifold was mounted to the cylinder upon arrival.) The head pipe, which had been cut and welded and then touched up with a die grinder to clear the rear powervalve, would not fit. The powervalve cover on the rear cylinder was holding the head pipe from sitting flush on the exhaust manifold to head pipe gasket. I called Paul expressing my displeasure. He stated that he wasn't sure how the grease got into the engine and that the pipe had to fit tight to help hold the rear powervalve cover in place. Not once in our conversation did Paul offer to "fix" the problems. I went from very excited to very disappointed.
I cleaned the crankcase out and took my die grinder to the under side of the head pipe and in about 30-40 minutes had it ready to install. Took it home that evening (had it delivered to the Yamaha dealership where I work as a technician) and began installing the other components. When I tried to bolt up the pickup plate the bolts would only go in afew turns. The cases I supplied Paul had been sitting around quite a while. I didn't know it at the time but evidently the stator mounting holes were full of dirt. No big deal just clean it out with some carb spray and a tap. Then I thought about it. How could he have "dyno-ed" this engine without bolting up a stator? This made me curious. I pulled the head off and found NO evidence that this engine had ever been running. There was absolutely 0 carbon on the domes nor any on the crown of the pistons. Pauls response to this was that he didn't dyno it after he fixed the water problem and that when he dynos an engine he uses the 760 or Kawasaki 750/800 style ignition there for he doesn't use those bolt holes. Here's where another thing that doesn't add up comes in to play. The cases I supplied him had been rewelded where a customer had tried to pry his flywheel off and broke a 1 1/2" portion of the lower case at the 6 o'clock position. When Simms racing repaired the cases they got the alignment of the bolt hole slightly off. Either Paul never bolted the cover mounted stator or it is possible he just didn't use that hole.
A few days later I had the engine installed complete with NEW 48mm Full Spectrum carbureters, manifold, R131a Rad valves and Mikuni dual line fuel pump Prok flame arrestors and fuel filters along with NEW MSD pro digital multi channel total loss ignition system. I take it to the lake and it runs good...for about an hour or so. The engine began to bog down low and on the trailer it would run away. It had an air leak between the cylinder and the cases behind the magneto where the "pry" relief is. Took the ski home, called Paul and bitched some more. Again he did not offer to "fix" the issue. I disassembled the engine to find a stock gasket that was trimmed to accept the big bore cylinders, but not trimmed to match the oversized and additional transfer ports of the DASA cylinder. The leak was caused by the one of the transfer port openings on the cylinder to case mating surface extended over into the hollow portion of the upper case. Yes, the same cases that were supposed to be epoxied...but weren't. After further disassembly it became apparent that the engine cases were not ported at all. The cases had been clearanced to accept the additional 6mm of stroke. It was not machined, looked as though this "professional" engine builder had done it with a die grinder.
I spend the next few days filling the cases with epoxy and decking the high spots created by the epoxy. I also did a minimum amount of porting to the area of the top case half to make a smooth transition from cases to cylinder assembly. When I finished and reassembled the engine and lake tested I couldn't believe the difference. This thing will rip your arms off from the instant you touch the throttle.
I received the engine before I ever got a bill. After a few calls to Paul asking for a bill I quit calling. One year later in Crystal Beach at the same Lone Star Freeride where I first contacted him about the build we talked again about a bill. He said he would have to get back to the shop and sit down and work one up. A few weeks later a bill arrives showing the $2678.something credit and owing an additional $850. When the bill arrived I called him letting him know that now we needed to discuss my bill for having to do some of the work he was supposed to have done and the work that wasn't done properly. We agreed on a price of $600.
Where I made a bad judgement in this deal was continuing to think about everything. I decided that Bull********, I will not pay him another dime. I had to redo everything and still wait one full year from our original talk to finally get a price. Screw that!
This spring I paid him the $600 after a few back and forth pms and cut ties.
my thoughts exactly.:shrug:
very sad reading to someone thats friends with all involved.
Awesome... that is the invisible super duper Dyno... I have heard about it and cleaned his shop and moved him.. I never saw it either... LIAR !
I'm the asshole.. LMFAO ! Thank you Kaveman..
There is a couple more of these stories that will be up tomorrow.
Until then..... buy something.. http://www.x-h2o.com/threads/p=337575#post337575
Thank you ! :Banane35:
Pete my first post on this was not directed to you.I asked not to be involved in this.my second post was Directly twards you.cause after i asked you dug up some stuff.which like i said i couldnt post pics and kept adding to it so what goes around comes around.Now keep me out of this.
