michael950
for me to POOP on!
- Houston, TX
Idok, what did you end up buying?
2x2, etc?
2x2, etc?
Looking for stuff, any leads?
Need to know what type to buy.
anything with Kevlar is giong to be harder to cut. kevlar shears are $90 or so
anything with kevlar is also going to be harder to sand/grind because of the kevlar fibers - so lay it down right as you can't grind it down like you can with glass.
I will second the post about sewing around the edges,I have an industrial sewing machine though so that makes it much easier
I'm going by what I was told - but then I think we were talking about straight kevlar - not the kevlar/carbon weaves.I'll disagree here, based on a bit of experience. Yes, Kevlar is a lot tougher to cut. But I have been using heavy duty scissors from Michael's for almost two years now, without a hitch.
will a standard machine work??? I picked one up a year ago really cheap at a garage sale
A standard machine will work with a special needle and use the heavy duty nylon thread.
he got the blue/black carbon kevlar.:sneaky:
the carbon Kevlar isn't really gong to give you that much strength anyway......unless its vacuum bagged
it does give a little support, but not near what it would with a vacuum system.......its mostly for looks
what about Texalium?
provide strength? or just for looks?
So are you better off just using fiberglass for reinforcing and strength?
