- Finland
but pop off do i go with stock 55psi or should i lower it?
wow two totally different version=) should i go to middle or?![]()
What kind of gas are you running? 1 over with 33cc domes is near race gas territoryHi guys im struggling with the set up in my b1
The spec is as follows
Stock 61x case and barrels
Apt girdled head with 33cc domes
+1mm pistons (82mm)
Riva manifold and pipe
Wetjet inlet with built in stuffers
Tau ceti arrestor
48mm annular carb
150 main
125 pilot
2.3 ns
Unknown pop off (guage coming soon)
Cdi with Rev removed
My question is where should I start with jetting please?
Does this look close or a mile off?
Thankyou in advance for any advice
I'm a bit stuck
+1mm pistons (82mm)
Tau ceti arrestor
48mm annular carb
150 main
125 pilot
2.3 ns
I'm a bit stuck
I'm no expert but that seems pretty low for 33cc domes. Ada recommends 100 Murican octane for them. And that's without a bore.I'm getting 175psi
Compression psi changes with elevation. If you are not at sea level you will get different results.I'm no expert but that seems pretty low for 33cc domes. Ada recommends 100 Murican octane for them. And that's without a bore.
Sent from my SAMSUNG-SM-N915A using Tapatalk
