The gas gm trucks that have the cylinder cut for fuel mileage is the cause for the trans failures. The trans is programmed to slip the converter while the cylinder cut is activated to limit vibrations and shudders and it causes the converter to come apart and go through the rest of the trans. A good friend and riding buddy is the trans guy at a local shop and probably top 3 most intelligent automotive person I know rebuilds that exact trans several times a month and talks about that exact issue all the time haha. If you can turn that off, you won't have any more trans problems. Gm only has that issue with the vehicles that have the cylinder cut.Had to replace my transmission last weekend.New reman I got the gm dealer said most people get about 100k out of them.
My truck is older (2012) and doesn't have the cylinder deactivation option.The gas gm trucks that have the cylinder cut for fuel mileage is the cause for the trans failures. The trans is programmed to slip the converter while the cylinder cut is activated to limit vibrations and shudders and it causes the converter to come apart and go through the rest of the trans. A good friend and riding buddy is the trans guy at a local shop and probably top 3 most intelligent automotive person I know rebuilds that exact trans several times a month and talks about that exact issue all the time haha. If you can turn that off, you won't have any more trans problems. Gm only has that issue with the vehicles that have the cylinder cut.
4l80e is for sure one exception to that rule.GM hasn't made a good transmission since the 70's.
I have a 07 Double cab now. 100% more room in the back than the 2022.The crew cab has all the room in the back. I used to work for Toyota, I swear the older 08+ tundra double cab had more room than that in the back. That's nothing there
I wanted the Double cab with the 6.5' bed. Now looking towards the Crew Max cab with 5.5' bed. Hope I fit in it better. If not, looks like I'm shopping for a clean 2019+ w/low miles.You got to get the larger one!
TH400 was definitely indestructible. Only transmission I never had a problem with. And I had a several, lol.GM hasn't made a good transmission since the 70's.
I was all in on a New Tundra double cab. I put money down. (Refundable) The dealer got a demo in. I looked at it, opened the rear door and was shocked there was absolutely no room for legs and feet! Deal breaker. View attachment 421335View attachment 421336
Woah, my 08 Tundra double, not crew, looks way roomier than that, WTF?I have a 07 Double cab now. 100% more room in the back than the 2022.
Funny you bring this up, first thing I noticed about this is how much is going on between the 10spd automatic and the auto start/stop. I hope I don't have to add batteries and starters like washer fluid. Can anyone give a LTR on the 10spd automatic?The gas gm trucks that have the cylinder cut for fuel mileage is the cause for the trans failures. The trans is programmed to slip the converter while the cylinder cut is activated to limit vibrations and shudders and it causes the converter to come apart and go through the rest of the trans. A good friend and riding buddy is the trans guy at a local shop and probably top 3 most intelligent automotive person I know rebuilds that exact trans several times a month and talks about that exact issue all the time haha. If you can turn that off, you won't have any more trans problems. Gm only has that issue with the vehicles that have the cylinder cut.
It is. Not sure what they were thinking on the 22 double cabWoah, my 08 Tundra double, not crew, looks way roomier than that, WTF?
I'm on my second truck with the 10spd. No issues. I find it very smooth. It's interesting to watch it accelerate and skip every second gear if you have the RPM up enough. I only had the last one four years, so nothing too long term.Funny you bring this up, first thing I noticed about this is how much is going on between the 10spd automatic and the auto start/stop. I hope I don't have to add batteries and starters like washer fluid. Can anyone give a LTR on the 10spd automatic?
Glad to hear it! What kind of mileage was on your first? Did you have the auto start/stop?I'm on my second truck with the 10spd. No issues. I find it very smooth. It's interesting to watch it accelerate and skip every second gear if you have the RPM up enough. I only had the last one four years, so nothing too long term.
I lease now because I don't do much driving anymore. It had 60k. It had the auto start/stop. No battery issues, no starter issues, but I didn't have it long enough to develop something. The battery is huge, so it should be okay. It's not like the really small and cheap quality battery honda uses that crap out the day your warranty runs out.Glad to hear it! What kind of mileage was on your first? Did you have the auto start/stop?
Thanks for the info!I lease now because I don't do much driving anymore. It had 60k. It had the auto start/stop. No battery issues, no starter issues, but I didn't have it long enough to develop something. The battery is huge, so it should be okay. It's not like the really small and cheap quality battery honda uses that crap out the day your warranty runs out.
My side hustle is to drive cars between Toronto and the Miami are for snowbirds. I've driven a lot of high end cars with all the features. It's obvious that Ford puts a lot of R&D into their features. The start/stop on my F150 and my wife's Escape are very smooth compared to other brands. The only cars that have more "refined" features seems to be Mercedes. Acura, Lexus, Genesis features are just there to say they have them. I turn off all driver assists. BMW is nice, but I feel like Ford is at a similar level.
My wife drives in stop/go traffic to work every day. Her Escape has 125km on it over four years and hasn't had a single issue other than two cracked windshields from stones hitting it. Her stop/start is used very often. I'd expect the Escape to have issues before the overbuilt F150.
