- Del Mar, CA
Put me down for one Mr. Carl...we are building a new boat that will have lots of Cold Fusion parts on it in a couple of weeks!
I'm stoked!
I'm stoked!
do they still have the lip seal on the bulkhead like the oem's?
can't see in the pic.
No doubt! I told Db that I needed a clear coupler cover to show off my Cold Fusion couplers since they look so nice. Doesn't someone make one of those? Blowsion maybe? You can't go without of course - the coupler will splash water all over the engine compartment - and straight into your carbs.
I run small billet couplers and a 550 bilge along with a one way valve with no coupler cover and dual 48s with prox f/a and have no issue with it even in surf and deep stabs
We accidentally discovered this too. The small diameter couplers are far enough from the bottom of the hull that they don't present the same problems with splashing as the stock couplers do.
Aaron
So grease does not go to the bearing?
