- Lacey,wa
When will they be available.
:sneaky::sneaky::sneaky::sneaky:
That wasn't there when I walked thru the booth
Pull your tank, drain it, allow ALL fumes to disipate-fill with water, use a heat gun on the side that contacts pipe, heat till soft, press it inward making a dent to clear the pipe.
Takes about 1 hour from start to finish for this project.
Why? You would lose fuel capacity.
Cool love the red, is a 3-4+ pfp compatible tank on the horizon ?
Just unscrew the cap and look in! Or make a lexan cap :Banane19:Thanks will comes in off-white, red, and black. There are no plans at the moment to have a "clear strip" to see fuel level. You should still be able to see the fuel level when the sun shines on the red one, but no luck on the black one. Just make sure you fuel up when you go in, and you shouldn't have any problems. haha.
Carl whats your web address? I need some motormounts
+1.Now thats something that there seems to be a market for as the PFP are seeming to become the new pipe of choice. Well, at least for many of the hardcore enthusiast .
