The tanks are 1" slimmer than an OEM. Thanks are molded from cross linked polymers make them super tough. Capacity is just slightly less than OEM.
Production version should be done here soon. Still need to do some drop testing on some of the prototype tanks. Plans are to fill them full of water and drop them off the roof. We hope to get some video.
Setup comes with tank and fuel pickup that has 4 NPT ports. The pickup features solid stainless fuel pickup tubes. You can see a pickup sitting next to the black tank in the picture above.
Thanks will comes in off-white, red, and black. There are no plans at the moment to have a "clear strip" to see fuel level. You should still be able to see the fuel level when the sun shines on the red one, but no luck on the black one. Just make sure you fuel up when you go in, and you shouldn't have any problems. haha.
Entire setup will cost $350. Compare this to purchasing a brand new OEM tank and separate Cold-Fusion internal fuel fill for OEM tanks, and you can see the savings.
The tank seen above installed in the Foot Rocket is one of the prototype versions and the black one is near production version. The aluminum just hadn't been anodized at WF. We had some folks begging us to buy them but couldn't due to liability issues of not having the aluminum anodized yet.
