This is a branch off from sx sxi sxr Aluminum Handle pole over at pwc2d
I have access to Autodesk Inventor and have been playing around with some pole design which also includes Finite Element Analysis strength and weight optimization. Any positive or negative comments relevant to the thread will be appreciated.
How many variations would be needed for a pole?
300/400/440/550sx
650sx
750sx
800sxr
fx1
snsj
rnsj pre?
rnsj post?
Also
stock length/-2/-4/-6
For all of those I would need pole curve radius, hinge bushing outer diameter, distance between bushing flanges, the turnplate mounting setup, turnplate stop, steering cable mounting method & bracket. Kawasaki poles could go without a separate chin-pad, Yamaha poles would need a chinpad due to the inverted steering end. I am aiming for the pole to be light enough to not need a pole spring due to the added complexity, breather tubes could go along side the electrical and steering through the holes near the bottom. Production will likely never happen, I have no means.
For your viewing pleasure:
Conditions are: Pinned at the bushing surfaces, Torque on handlebars ~ 125ft*lbs modeled as 500lbs directed up 1.5" from center of turnplate and 500lbs down -1.5" from center of turnplate (imagine trying to twist the pole along it's axis/roll the ski over). Length from pivot to center ~30". Material is 6061-T6 Aluminum and of course not set in stone. The I before a letter stands for Iteration. Displacements in the model images are 100x actual.
I1 5.35lbs MaxDisplacement .150"
I2 5.79lbs MaxDisplacement .053"
I3 4.72lbs MaxDisplacement .178"
I4 4.84lbs MaxDisplacement .113"
I5 4.25lbs MaxDisplacement .282"
I6 4.30lbs MaxDisplacement .245"
I7 4.31lbs MaxDisplacement .240"
300/400/440/550sx
650sx
750sx
800sxr
fx1
snsj
rnsj pre?
rnsj post?
Also
