Crabs X2 winter buildup
Crab
thanks darin...noswad!
Seattle
Lookin' good!
Which 2 part foam did you decide to buy?
I just finished sanding the bottom of my hull. I didn't get as far as I wanted by today, but maybe after feasting, I'll go back out and try to install my check valve.
I decided to go with the 4lb, it is stronger and should take the shock and impact better from the waves. I will also use it to foam in around the one way and for filling in under the gas door. I'm also going to get a gallon of their epoxy and hardener, way cheaper than the West Systems.
Crab
Seattle
Update: I got the interior ready for reinforcement today, grinding down the tiny upper ribs but leaving the beefy lower ribs in place. Ordered supplies from US composites, on to foam and glass hopefully next weekend. Wifes boat going up to the loft for winter storage.
Crab
Seattle
Got my long curved deck brace in the mail today, 5 minutes of tweaking and it fits the right side just like the left one. Now I can do duals with ease.
Crab
Seattle
Got my chemicals today, couldn't wait to play with the foam!:arms: :arms: :arms: :arms: :arms:
Crab
Seattle
Working on the X2 today. And some carnage at the crabshop.
Lookin' good Crabman!
So you decided to use the expanding foam and trim it to get the shape you want (I like this idea)...
What did you do to the hull before pouring the foam to get it to adhere?
Crab
Seattle
Some sanding, and rollock surface prep tool. Im heading back to the shop now,
Crab
Seattle
More progress today.
Crab
Seattle
More today. Not sure I am 100 percent comitted on the shape yet, after the epoxy is cured in the morning, I will sand it out and check it all for true. I may narrow up the very front center a tad before I call it good.
You really continued the shape of the bottom forward well.
I see what you mean by the shape of the underside. My hull comes into a point.
I wonder if this even matters since we ride with the nose up more.
I'd better get on the ball if I'm going to have a whizbang ride like yours this spring, or just a pile of parts that never got assembled.
WFO Speedracer
Alabama
I had a similar thought today Crab but I was going to use a solid shapeable foam and cut my rough shape into it and glass over it.Good job .
Crab
Seattle
I was going to do that, but I want it to bond good and not have to worry about the epoxy melting the foam.
Crab
Seattle
I did narrow it up in the nose about 2 inches, it looks way better and continues the strakes forward cleaner looking. I know this new shape will get rid of the goofy handling issues with the X2, and may also negate the need for tubbies. Ready for glass now.
Crab
Seattle
First coat of e-mat over the foam, I will follow it up with one layer of cloth for the final layer with white pigment added.
