185 psi is 93 octane. So anything higher requires race gas mixtureWhat is the max psi you can run a cylinder at before needing race gas?
The only thing i can think of is maybe cylinders didn't have enough oil in them for the rings to make a nice seal. And by holding the button in for a few more seconds your N&S came unstuck and pump fuel into the cylinders. The Sticky N&S could also cause your engine to not idle.
Just a thought.
I remember cranking a motor with a comp tester and it read 120psi then poured so premix in the engine and turned it over a few times and rechecked and it went to 160psi.
