Air in the fuel line is the most likely culprit...it happens. The first fix for that is to let it idle for 5-10 seconds before trying to rev it after removing fuel lines. If the tank was low on gas, that's another culprit. A leaky primer can cause it too but I'm betting it's one of the other two. If it does that again, pull the throttle. Seems like the last thing you should do but it's the only real solution. The plugs get super hot and they ignite the small amounts of fuel and maintain the ignition. The additional fuel cools the plugs and stops the engine.
I've had it happen for 5-10 seconds after a ride and the engine got hot enough to boil water instantly for a couple minutes. I also blew the head gasket once and didn't realize it until the engine shut down. That engine continued to run long after both of those. Hopefully it wasn't really 90 seconds but one of the guru's will have to chime in on what that will really do to the engine.
