D-roc's 96 Rn
D-Roc
I forgot!
2011 Yamaha XFS build.
Well hell must have froze over cause i finally got a RN hull to ride. Its a solid virgin hull with typical water logged foam for its age. Even though it's not winter yet i just can't help to tear into it. Gotta get the foam out, scupper in and the hull cut. That is the main focus for now.:icon16:
D-Roc
I forgot!
i got it defoamed, the cooling lines removed, back of hull marked for cutting, pump shoe removed/ fixed. i weighed in on the bathroom scale and got about 87lbs. lots more ginding and cutting to do tommorrow.
thegoldenboy
RN Surgery... soon
Toronto
Dude you did it! RN Finally!
Hull marked for cutting? Ohh Christ, here we go now.. Not going to be ready for Ipperwash I assume...
Glad you found a hull.
BTW I'm picking up an 02' tonight :smoker: let the celebration begin.
D-Roc
I forgot!
one night?....more like a couple hours, pressure washers are my friend, my grinder quit on me so i didn't get all the cuts done on the hull for shortening it, i did remove the pump shoe and fix it with PC-11 and sealed it all back in as well as the outside part of the tube for the drive shaft. Tonight i should get some work done, actually people are coming over so....maybe some beer drank instead.
D-Roc
I forgot!
i managed to move one ride plate insert, cut the hull, sand the bondline even, i started glassing the ends of the hull, also removed alot of the green glue and resealed the anchors with PC-11. i also cut the hole for the scupper in the bulkhead, still got to do the one in the pump cavity. making some progress i am in no hurry, its not going to be ready for FSF or anything but i will ride it next season. I am thinking.....no foam.
the hull is quite a bit cleaner now.
normal_100_0363.pg
D-Roc
I forgot!
Front exhaust only? I may need to check this out in the near future. Roadtrip to Dunville.
anytime, its always a party at the shack, :fest06:
i was able to get most of the foam out with a big screwdriver but the little stuff that you have to scrape i used the pressure washer. I have done an entire ski with a 0 degree nozzle on the pressure washer through the exhaust hole and scupper hole and yeah it was messy...no bloody knuckles though. I filled in the front fuel hole tonight and started sanding, i hate sanding so i walked away for now. tommorrow i will hit it up a bit more. i weighed it again and it read about 83 lbs but we are going to get a digital hanger style scale tommorrow cause the bathroom scale is just too inacurate. (sp)?
brentR
way fast whitey
Toronto
thats the plan, not lookin forward to ripping up the turf I just did like 3 months ago LOL i gotta redo my holds too they are too far back...
D-Roc
I forgot!
i got my scupper/oneway installed and epoxied in. I also did the two cooling lines. i filled in the front gas cap opening too, that is a tough one to get to look prefect! its close, flat black is more forgiving than gloss so i may or may not work on it a bit more.
