The bendix actually worked fine. It sounded a little dry though. I will use a different pulse line plug if someone can show me a better cheaper one than I used.
Sent from Canada
http://www.mcmaster.com/#9753k12/=106fca6
Sent from Canada
Cookin do you want to be banned again?
It's starting to pit a little I need to touch up a spot.Wow look at that another motor with who knows how many hours with good pistons...lol. Whats the case porting look like on that baby.
Nothing is cheaper than a used bolt off the floor and a little fuel line, but it is nicer. I can use something like that for sure.Well with shipping and conversion to Canada prolly not cheaper
Yes I think that's the reason. Do you know the exact measurement?@D-Roc what causes the stock drive shaft to have less engagement? Is it because the oem 155 has that bigger bearing in the front
Brian, this is the GTA thread, none of this 1/2" stuff, you should convert that to Metric!Big bearing is only for set back pumps. reg width bearing for reg housings. the 155 pump is set back further than the 144/148 housing. you will end up with approx 1/2" worth of engagement.
