Frosty
New York Crew
- Western New York
Did you get some readings on the temp?
Yeah thoese racetemp stickers are cool.
Brian's 971 is running ~140 degrees... I still need to get a sticker from him for my motor...
Steve at KOMMANDER suggests adding a cooling line into the motor tapped into the water jacket towards the top of the head on the side it cooled my right down. I also went with parallel cooling to keep the exhaust a little cooler.
Whats everyone using as resistors? Trying to find something locally I can drill out
Interesting, You can go to the stinger from the headpipe outlet, Then use the 4th Line as a dedicated flush!!!!!!!!!!!!!!!I set my superfreak up this way and will do all future ski builds the same. 2- 1/2 od lines from the pump to a 2 -1/2 inlet- 4 3/8 outlet manifold. 2 3/8 lines fees the engine exhaust manifold and out to 2 pissers, 1-3/8 line feeds headpipe and out to a pisser. The 4th 3/8 line feeds the flow control valve to the stinger. Setting up this way allows the use of restrictors in the bypass lines if more water flow is needed to dial in the temps of the engine, headpipe and stinger.
Interesting. Thanks, i might widdle up a manifold all 1/4npt 3/8 fittings. Looks like i have 1/8npt on the manifold too, which prolly isnt helping.I set my superfreak up this way and will do all future ski builds the same. 2- 1/2 od lines from the pump to a 2 -1/2 inlet- 4 3/8 outlet manifold. 2 3/8 lines fees the engine exhaust manifold and out to 2 pissers, 1-3/8 line feeds headpipe and out to a pisser. The 4th 3/8 line feeds the flow control valve to the stinger. Setting up this way allows the use of restrictors in the bypass lines if more water flow is needed to dial in the temps of the engine, headpipe and stinger.
That was an option, I made some fittings that slide right into the pisser outlets to flush the engine out. I just wanted more water pressure on the flow control valve so it opens and closes better.Interesting, You can go to the stinger from the headpipe outlet, Then use the 4th Line as a dedicated flush!!!!!!!!!!!!!!!
I got the manifold and fittings from mcmaster. I also used some quick connect fittings for ease of engine removal and installation so I don't have to deal with hose clamps.Interesting. Thanks, i might widdle up a manifold all 1/4npt 3/8 fittings. Looks like i have 1/8npt on the manifold too, which prolly isnt helping.
I just added 2 more fittings on the head and out the scupper, easy to try. Will test tomorrow with a temp gun.
I am running 2 - 3/8 lines off the pump, but i dont think thats the issue, seen plenty of people do it.
