DylanS
Gorilla Smasher
- Lebanon Pa
i Have a set of gp800 cylinders that were over bored and resleeved, and ported for a 5mm stroke
Basically I can’t get new cylinders
Every single head bolt is completely stripped out, and the guy who helicoiled it before absolutely butchered them to the point where I can’t even get them torqued.
I’m desperate, does anyone have any idea on how to even begin to fix an issue like this?
I can’t use inserts as the threads are crooked
Was considering having someone stick weld aluminum into the threads and having a machine shop drill and tap it out, but I’m scared it’ll warp the material around it
Anyone have any idea if there’s enough material to have it drilled and tapped to a 10x1.25?
Any suggestions would be a godsend at this point, thanks
