Hey guys, I've been working on fixing this for the last 2 days- trying to identify and resolve this problem & just finally found one inconsistency.
Basically I noticed after maidening my new motor I noticed the front cylinder powervalve wasn't moving at all but rear was.
I've done every possible diagnostic with the engine together. Comp & squish even, swapped ignition leads so its not timing.
Running ATP flame so single pickup, even spark.
I then swapped front pv to rear, same thing, rear moves out, front doesn't- so it's not the pv itself.
Pulled head off and inspected- everything perfect even in every way!
This is the only comparable difference I found from front to rear cylinders- the wash on the domes!
So how does this translate to causing my front powervale not to move?
(Front piston is the dome on the right in pic)
48novi's were rebuilt exactly the same in all aspects so im pretty darn sure it aint them either!
Full engine specs as follows.
Xs1000 90.5mm, 200psi, 1.15mm squish
48 novi's, VF2's
ATP Flame total loss
Power factor pipe
Uploaded with ImageShack.us
48 novi's, VF2's
Power factor pipe
