Maybe we have differing opinions on what "light switch" power is. It seems some are thinking the light switch is when you nail the throttle from idle and it ramps up smoothly and then kicks hard in the middle of the rpm range like a turbocharger.
My idea of a light switch is when you nail the throttle from idle it yanks your arms hard, then if you back off and maintain speed in the middle rpms and nail the throttle again, it yanks your arms in roughly the same way. Then if you're cruising along at half throttle and let off, you get eye opening deceleration. I can finesse the throttle if necessary but I use the big throttle hit way more than I patty cake the throttle.
