Super Jet difference betwen stock 144mm pump, and a stat trak mag pump. 144mm
steve-uk
Manners cost nothing
Barrie - ontario
Say whatever you like here cause I could care less
I have both a 140 and 144 mags and Im in no rush to get rid of either. You guys come ride a flat, land locked lake and tell me a mag isnt worth the money. I cant believe some of the comments Im reading here.
Quite a few of you Boys need to find out first hand and not drink all the kool-aid they try and serve you!
anyone that thinks there stock pump is better has no clue. i cant ride a boat without a mag pump anymore. even with a limited 701. 140 144 148 are all good pumps. i have 4 boats i ride they all have mag pumps in um. so does my blaster. hell i even put a 148 mag in my stock b2.
x5000
im coming to to conclusion that anyone who says mags do nothing, either:
1. have never tried one
2. cant afford one
Mmmmmmmmmmm koolaid !
JetManiac
Stoked
orlando
i dont think many could tell the diff in flat smmoth water either,in a blind test.they shine in whitewater,but its a waste of money otherwise
Rubbish!!!! (said respectfully to tor)
Most mag pumps are bought for use in flatwater. They make a huge difference in any water, out of the water they dont make a difference!
Wolf Child
Just Another Octard
All over C. FL
First off I believe a OEM pump is 140mm not 144mm, however the main difference between a Magnum pump and a stock pumps design is such that a Magnum pump requires less water to pressurize the pump and produce thrust. This advantage is really only noticeable in rough/churned up water conditions such as on a race track following in someone else's wake or in the ocean on the whitewater created by a breaking wave. In smooth water most people can't notice an advantage of a mag pump over a stocker.
you sir, need to not comment on things you obviously have no clue about. there is no conceivable way you cannot notice the difference on a mag pump in any condition.
is this really even a discussion?
of course you can tell the difference beteen a mag pump and a stock pump in ANY condition
Hell you can even tell the difference by looking at the jetstream...
with a stock pump the stream is streaked completely aerated and streaked with white
with a mag pump the stream is much darker blue....no air
tor*p*do
Squarenose FTW
NW NC
I went from a 14/17 skat to a 10/16 hooker and it made a huge difference on my sski!
call Dave at Impros and ask his advice!
SN, 61x/x, mod b, 718 wisecos, shark fab 35cc/185psi, msd enhanced, freestyle ported, stubby cone, etc
Its all about the surf!
Oceanside, CA
WOW getting cruxified in this thread! Lesson learned!, don't offend the Magnum pump cult! This guy even thinks I just fell off the turnup truck!
SO tell me just what magical combination are you guys running that's getting you so much better performance from your mag on SMOOTH water? I really want to know because I have two identically set up limited Superjets with the exception of the pumps. One has a 140mm set back Mag with a 14/19 skat and the other has an OEM pump with a 11/17 hooker. Like I said previously, my Mag equipped ski really shines in both churned up flat water and in the whitewater of a breaking wave in the surf but on SMOOTH water their performance is pretty much identicle. So what prop pitch should I be running to get this fantastic SMOOTH water performance?
Hey John.
I went from a stock pump with a 13/17 Skat Freeride Swirl with stock cone and stock nozzle to a 140 12V mag. Impeller is a Skat 13/17 (different impeller though!) With medium cone and 140 Skat nozzle bored to 82.6
Gains were phenomenal everywhere - awesome acceleration gains plus top speed gain. Most noticeable on flatwater.
When I swapped everything into the Superfreak, the impeller got pitched up to 14/17.
I can't take any credit for the pump setups - Art helped me with all that and he was spot on every time.
I don't know that any of this would work for you, though. My motor is kinda high strung.
Waternut
Customizing addict
Macon, GA
x2... I notice a difference in the chop and surf but I've tried a 14/19 and just put a 12/18 in my 140 setback mag but in smooth water, it's hard to tell the difference between a mag and a stock pump and hooker prop.
Hey John.
Maybe my trailing edge is too tall on all these props. I'm running 85mm bored nozzles too. Maybe I should try something smaller.
