post up a link to down load that file. Nice and simple and would save me making one. Thanks Pat
on what format of paper should i print it?
I just used standard 8.5x11 printer paper.on what format of paper should i print it?
i just printed this thank youI made that .dwg back in 2007 it got around. Here is the printable .pdf No need for it to be round angle is angle.
Diameter does not matter angle is angle.I just bit the bullet and bought a torrent pitch gauge cause it will do any impeller up to 160mm and goes down to a 5 degree leading edge. Lowest I've seen on any other pitch gauge was 8 degree leading edge
