Do Reeds help Performance
steve-uk
Manners cost nothing
Barrie - ontario
I dont get how they could possibly leak any more (or close as much) as the boyesen reeds....
its not the pedals that leak its the cage because of the way it all screw's together
Ah... Apprently Ive never inspected one very closely then.
and until you get symptoms of an air leak youd never even look at them either
but id recommend if your taking your intake apart for any reason, pull out the reed cages and check the screws are tight that hold the cages together
me and junkyard found that fault on my 701 motor, everything looked good, pulled out the cages and one of the assemblies had come loose... just one of those things.. maybe loctite would help but its a screw going into plastic
