- boston
looking to get one rebuilt?
That spring around the weights will wear through and break. This is the root cause of many damaged stators. Inspect and/or replace it every season.
Where do you get a new spring.
do you have to pull the motor to change the bendex or the spring? I've never had my flywheel cover off to be honest.
You can pull the flywheel and the bendix with the motor in the ski. But considering how easy and fast it is to pull the motor, I would just take it out to do it.
I think its easier to just remove the fuel tank, then fly wheel cover, flywheel, bendex
thanks, I would prefer to avoid wrestling with the pipe if possible but can pull the motor if need be
anything special or tools required to pull the flywheel? I believe I've read about a flywheel puller?
Cold-Fusion makes a flywheel holding tool
Yes you will need a flywheel puller and an impact wrech
