back to the top again
sorry guys to bring such an old thread back, but I thought I would ask for help in here since this has been a great thread.
I recently got myself Paul's lehr 61x big bore freestyle ported cylinders with R&D manifold that works with Vforce 2, protech griddle head with 35 dooms (~187 psi is the actual compression), hooker 10/16 impeller, and dual AM 44mm silver carbs with brass 90 degree fittings. the carbs were jetted by Paul as follows.
120 pilot - 1/2 turn out
130 mains - 1/4 turn out
2.0 L/S and 95 grams spring
62.5 main in the return line.
that went into my 04 superjet with Rad flywheel, B-pipe mod with dual cooling, MSD enhancer.
with the above jetting, I had off idle lean hesitation and OK snap. I will list what have I done in terms of jetting and my findings below.
- increased the pilot to 125, that made the hesitation much less obvious, but the throttle response was worse. final jetting was 125/130/2.0/95
- dropped the pop off by using 80 grams spring and kept everything else the same, that made the hesitation go away, but the throttle response was even worse. 125/130/2.0/80
- dropped the pilot to 115 just to see if the throttle response improves and upped the main, that made the throttle response better but the off idle hesitation was pretty bad. 115/135/2.0/80
- went back to 125 pilot and dropped the high to 130 but this time I thought I would try even higher pop off, so I went with 115, that made things 10 times better (or I thought so) so I was not getting any off idle hesitation and the hit was good but
while I was going at a steady ~1/3 thottle or so for 4 seconds, the ski suddenly lost power and the exhaust sound was muted, it almost felt like seizure. let go and tried again, same thing. so I thought I would richen the low screw and see if that helps, and it did, I turned the low screw to 2 full turns and that took care of that issue. I stoped there and decided to go home and do a compression test and the numbers were healthy (~187 in both)
next day, I thought I am not that way off, so I lowered the pop off via using 95 spring instead of the 115, and that did not help, the very same thing happened (seizure) put bigger pilot (127.5) still the same thing but this time if I turn the lower screw at 1.5 turns it will run ok (however by now the throttle response is no longer that great)
so I got kind of sick and put 130 pilot and 80 grams spring at the same time, and that sure took care of the seizure issue, keeping on mind that this only happens when steadily ride at ~1/3 throttle for several seconds or so not WOT at all.
so my final jetting so far is 130/130/2.0/80 the good thing about that is I no longer have off idle hesitation nor 1/3 throttle seizure. the bad is I have what feels like rich spot at almost 1/4 throttle (if I advance a tiny bit after that the skit would jump right off the water) off idle response is kindda lazy/muddy and loading during tail stands.
so what do you guys think I should do next, I mean having 130 is kindda big, but any lower than that and hesitations and seizures happen. should I leave the pilot at 130 and drop the main to see if that helps?? I don't have a tach to tune my high end though, I have been trying to find one in here but could not so far
any help would be greatly appreciated, please note that Paul has been trying to help me and I have had an excellent experience going with him for my build, but I guess he has been either busy or away in the last couple of days and that's why I thought I would ask you guys for help until he gets back to me with his thoughts.
thanks
Ahmed
