douglee25
m3booooy
- South Jersey
If you NOT using 62T cases and using 61x cases, Use the Wetjet 46mm carb complete w/manifold! That Wetjet set-up will work very well when you can find them.
Roger that. :biggthumpup:
Doug
Chris, AND the rest of you that are trying to use the stock OEM carbs are very hard to tune for FREESTYLE throttle hit! (remember Yamaha made them for fuel ECONOMY and some added performance) Just sell them stock 760 carbs and buy some new 46mm's, freestyle motors require FUEL to have throttle response and stock 760 carbs WON'T cut it without a total circuit rework!!
Do you see any of the aftermarket carb guys building race carbs out of stockers, not much. Most Novi's, All of Full Spectrums and I think all of the Jetworks Blackjacks also use the aftermarket mikuni's for a base carb. How much is it worth to you to pay for an update re-circuit work on your OEM yamaha carbs, Just need to know if it would be worth my time to develop 760 carbs for this...
P.S. This is MY opinion only...I do NOT claim to know it all, I just know what work's for my engines...
Lets look at the SuperBN46mm carbs a bit. In addition to the carbs you need a throttle linkage, throttle wheel, bottom mounting adapters, and top mounting adapters (to use the OEM FA). Maybe throttle return springs and carb cable mount?
Will all these swap right off a stock pair of OEM 38 or 44mm carbs? Does the intake manifold need to be opened up or massaged? What about gaskets?
Who sells the best priced kit to swap out directly for OEM 44s?
Yes...the stock oem 44's Yamaha 760 carbs have the three hole low speed circuit.
One is for the low speed adjustment and the other two are the bypass holes.
Here is what I have on a ported limited 701 duel 44’s 62T cylinder stock flame arrestor and 180 on compression.
120 pilots
105 mains
2.3 N&S
80 gram springs
15 pop off pressure
One thing I noticed well Waxhead noticed is that I was unable to tune the motor properly
with reed stuffers so those went in the trash can.
Mark44
120 pilots
105 mains
2.3 N&S
80 gram springs
15 pop off pressure
Mark44
