I ran Tem's carbon superfreak box in mine when I had a b pipe. It's about the same shape as the old style x metal box.So what waterboxes fit without modifications to them?
Tpete are you still looking for a mid length x metal pole?
9/15 or even 9/14Prop Suggestion needed: 701, bpipe, with stock sxr pump. Thinking like 9/17?
I'm not 100% sure yet, building something more surf oriented.What are you moving to?
You're right., it's set up for yamaha running gear all the way through. No need to source a kawi pump. The steering cable still runs down the left side of the boat (kawi) but that's an easy change by just flipping the steering nozzle. I'll be including a lot of little extras that will be detailed in the sale thread. Perfect boat for a buddy with a square looking to do a swap.Gotcha! You should also mention that your hull is all yami
