Custom/Hybrid EME Q8/Aerial 8/Micro/Roid discussion thread
Is there any kind of scupper delete/block off/replacement etc. for the micro? Mine looks like its just aching to leak, and where I ride there are huge no wake zones and areas where I sit and float a while. I think the ski will just fill up with the scupper on it since it looks like it seals very poorly, the flap has like a 1/4" gap... Any advice? Thanks
N3vrSat1sfied
Military Member
Fort Worth, TX
My original sucked, EME sent me a replacement it was ok but still wasnt great. So I tried a few different things.
1) I did a block off plate with versa plug, The versa plug kept sticking closed.IMG_3958.JPG
2) Since that didn't work I Frankenstein one (EME rubber and top plate, Xmetal Bottom). This works great ran it almost all last season. (sorry only pic I have)10463867_10152248142036848_2847914307699159617_n.jpg
I had a leaker on my q8 as well. I would plug mine from the inside when riding surf with a 2" cherne inflatable test ball.
http://www.cherneind.com/Pneumatic/Test_Ball/
They can be found at your local plumbing supplier. I think I recall seeing someone using an aluminum plate in place of the flapper with a ball check on it.
SpaceCowboy
breaking something
The water pressure should hold it shut...only way to see if it leaks is by dropping it in water. These have been a nemesis of EME skis.
So as I start assembling this micro, I am becoming more dissatisfied with it. The pump was a nightmare to align, especially with those cheasy aluminum flex pump brackets, anyone have a better way if mounting the rear of the pump? Then I test fit the engine and its not even close to aligning with the motor mounts, I stopped for the night...Anyone have this kind of issue?
Here is a pic of my issue, midshaft is pressed in with 20mm out the back per spec using the midshaft and midshaft housing supplied by EME. Midshaft carrier is from a Waveraider, but all are the same across all later Yamaha's. Using raider motor mounts (too tall by 1/4" so I need to replace them), raider bedplates (again same as a Superjet), and Raider couplers. @tatronation I checked out your thread, unfortunately I can't do the pump mount like yours as there is no hull at the rear pup mounts... Any ideas? Thanks
clouse22
BDB Kustomz
Lake Orion, MI
You need the Yamaha conversion plates for the 4 motor mounts
You are supposed to bolt the plates to the hull...then set your motor mounts and motor in...mark holes and the drill and tap the plates
@N3vrSat1sfied @EvanKrefski @swannysxr
I saw the Yami pump conversion on Evans micro and I was unimpressed...IMO they need to stick with the kawi pumps or develop a new bottom mold setup for yami
