- Morris Ct
Sportfish has the right idea, just need a 2" version. I run at least 4 2.5" breather tubes on all my skis. More air the better.
I put those on top of my breather tubes for a while, They didnt keep out any water and actually killed the performance when they got dirty. The dirt would get wet and choke off all the air intake to the point the ski would not rev up past idle. It took some time to figure out the issue but I know Ill never use them again.Do those frog skins even work? My hood doesn't have any vents
Great thread, so how do I fit breathers to my new XFS?! I was thinking perhaps a couple of bilge fittings on the firewall piped up high then down do bottom of engine bay (to avoid run back)? Not sure this will give enough though?
You could order the ninja hood scoop and add some breather tubesGreat thread, so how do I fit breathers to my new XFS?! I was thinking perhaps a couple of bilge fittings on the firewall piped up high then down do bottom of engine bay (to avoid run back)? Not sure this will give enough though?
This is actually exactly what I did to my Footrocket. I was running dual bilges, but I found I didn't need them for the riding I do so I removed the bilges and just ran the tubes down to the bottom of the hull. My 1200 seems to run fine with just pole breathers and the bilge breathers.
would you notice a difference in performance if you block the bilge outlets up?
Most of the skis out there don't get enough air. Big motors need big air. I've experimented with it on many skis, including freaks, the red brawler with TPE 1105, my KDX, and some others. Everyone showed noticeable gains with more air. You have to balance air in versus potential water in for your application. Flatwater boats with big engines get away with more because a skilled rider won't ever let go of the ski. Surf guys have tougher conditions and may WD tv to compromise between the two. The XS hoods are all large openings. The smaller was the early design. They were one of the first to figure it out.
I've never added air and not noticed a noticeable improvement.
I also don't think XS was he first to figure it out, just something that has been forgotten.
That can be a challenge. They work ok with less air, but maximum performance (and significant gains) can be found with the proper amount of air. Getting that right is different with every hull/hood/pole setup out there.Ya, I'm thinking my motor would benefit from more air, but my hood doesn't have a liner and i really don't want to cut into my beatiful carbon hood![]()
