I am riding and don't have power and some times it's like going over a rock,looks like it's a Timing problem,
I removed the fly wheel, every thing is in good shape ,the key is not broken,
I take the compression,the gage is weird ,it does not hold the pressure ,it reads 180 and then150 psi
is it possible that the reed valve need to be replace
thank you for time
thank you for time
