Engine problem XS 865
I am riding and don't have power and some times it's like going over a rock,looks like it's a Timing problem,
I removed the fly wheel, every thing is in good shape ,the key is not broken,
I take the compression,the gage is weird ,it does not hold the pressure ,it reads 180 and then150 psi
is it possible that the reed valve need to be replace
thank you for time
A compression tester isn't a leak down gauge, if the compression bleeds off the gauge valves are faulty, and I don't understand "like going over a rock?)
I can not say back fire,I was with a very good mechanic when it happens and he was sure the key was broken , so the next day I removed the fly wheel cover and the fly Wheel ,every thing was in perfect shape, the key was not broken,
then I took the compression and the reading on the gage was weird, going to 180 and then 150 psi,
the power valve are clean, clean every 4 hours
