- Michigan
Can I get replacement bolts for the flywheel cover at my local hardware store? Are they 17mm? Can't find any specs via the part #. There are a bunch of bolts that are either missing or the wrong size
I ordered a few parts to replace including the pump seal. Yesterday I temporarily sealed it with 5200 so today I'll find out if that was the culprit. I'm learning a bunch as I go and doing things myself but hey.. It beats paying triple at the shop.
Nvm found it. They're M6 x 1 x 25mmCan I get replacement bolts for the flywheel cover at my local hardware store? Are they 17mm? Can't find any specs via the part #. There are a bunch of bolts that are either missing or the wrong size
First time my driveline stripped only noise was motor. Second time it has barely stripped and you could hear the spline slipping.If it were worn slipping spines you'd think there would be a secondary symptom of noise as the splines slip past each other
Yup I pulled the motor today and swapped out the starter with a spare I had laying around. The battery was low so the engine wasn't turning over but at least the bendix engages the flywheel properly now. However, after charging up the battery all I hear now is the relay click when trying to start. I sure hope I didn't fry the new starter..The starter is no bueno. gear is stripped at tip . You need a total teardown and replace with minty used oem parts as needed, they are actually easy to find right here on the X it will save you money in the long run . Good luck
Didnt you pull the midshaft while the motor was out? looks like the seal has an issue in blownup picture then check splines,bearings etc.
So I swapped out the internals of the starter with the housing of the OEM one that had a stripped gear. Works great even though I just ordered a used starter today. And the bogging out problem was because the main fuel line got disconnected lol Tomorrow will be my first chance to finally take it for a spin
Quick update: after replacing the pump seal (thanks JetManiac!) the ski hooks up flawlessly! I also disconnected the thermo switch from the CDI which was causing it to stay in limp mode. Picking up a PSI pipe today tooAll I need now are some pepe's to ride with. If anyone lives in the Oakland County Michigan area hit me up!
Sweet dude!! go shred!!Quick update: after replacing the pump seal (thanks JetManiac!) the ski hooks up flawlessly! I also disconnected the thermo switch from the CDI which was causing it to stay in limp mode. Picking up a PSI pipe today tooAll I need now are some pepe's to ride with. If anyone lives in the Oakland County Michigan area hit me up!
