my issue had nothing to do with the epic at all, ended up being water in my fuel tank and my jugs... i cleaned everything and dryed it out, so far its been running great
Did a new coil fix the issue I still have an issue with my epic it will not run correctly. It will also run on a stock ignition just fine.My problem was little to no spark. It might spark 1 out of 20 revolutions of the crank. If I isolated the EPIC from the electrical box, it would fire perfectly. But, with the EPIC grounded to the box it not fire. With a new coil it fired right up.
Theory is the faulty coil was "leaking" high energy into the box and interfering with the EPIC. A stock CDI worked fine with the coil, but the EPIC is more sensitive to this kind of issue (being digital).
Its ok I got the issue sorted the ski runs awsome now.
Ok I think I am having a similar issue so I will do some more testing and let others interested know what I find. It seems the factory cdi is very forgiving that is probably why the electronics last for 20 years but man from the looks of the basic pre loded safe maps the gains are going to be huge once I get the bugs worked out of my old as SN.
On a bit of a side note Steve from http://www.canadian-freestyle.com/ has been very helpful in getting me setup with the E.P.I.C. system even though I bought it from a forum member not direct from him he has shown the highest level of customer service he is very good to deal with.
Yeah I have heard there are some people who are not having an issue. Mostly it seems like mild boats ie pipe and head seem to run just fine with them. Its when they start loading them up with porting etc there doesnt seem to be voltage to fire the plugs and they foul.
I changed every part of my ignition system that I can think of. I even put in a new regulator in case this was the issue. In the end its cost me heaps to find out that my cdi was faulty.
I know for a fact I am not the only suffering from these same issues
