Boyer did you know we had a flash #11 that tells Epic to ignore some of the corrupt info that may cause a cranking issue?
Chris.
Hi Chris, What is the benefit to update the Flash#11, i bought mine in april 2011.
should i upgrade? so far i have no problem with my EPIC.
I didnt know that chris. I know they foul plugs but really how much ozone depletion can one jetski really do. Unless its of course from the shipping of the epic backwards and forwards.Boyer, its extremely unlikely that the rectifier/regulator would cause a problem as the Epic works with the AC voltage directly from the stator apart from the 12v DC that powers the circuitry. The only way I can see this happening is if the rectifier malfunctioned and put AC into the battery but you would know about this as the battery would not be very happy.
Hey Wax....Did you know that Epic has been accused of being responsible for the hole in the ozone layer down under?
Chris.
