Boris
The Good Old Days
- The surf-less coast
At regular gas stations it's 93.
XMetals 771 with all the bolt onsNot sure what motor you are running but they can/will load two curves. One more aggressive than the other. Install a waterproof toggle or one of the rotary switches and you are in like flynn
What do you do if you are a Tard? My epic is installed and I have no idea where to begin, my motor is a Jetmaniac 710, I run 93 octane and amsoil dominator at 40/1 per Jetmaniac. I was told the epic curves that come preinstalled are good, and I've heard that they are too conservative. My ski is in a million pieces waiting for the new hull to get here so I cant really experiment at this time.
Anyone have a curve that will hit noticably better than the stock cdi I had in before. Also I hooked it up per the diagram in the literature, but I have extra parts, I have another splitter and the red from the start stop switch is still not connected. I do some more research online and I'm sure I can find the answer unless someone wants to save me some of the legwork and help a brother out. Ultimately I'd like one curve I can ride aggressively, but I still need the ability to go wide open we run down alot of boats, and one that I can use in the surf. I ride flat water sometimes too. So should I rock 3 curves. I pretty much don't know where to begin if you can't tell![]()
Also I spent a day last week with an EPIC on a dyno on an engine that was also run with a stock ignition, it is fascinating stuff and I have a lot of facts and figures that are really interesting.
Chris.
